It-works
Sep 08, 2023Follower
DHCP settings
Netgear AC1750/R6700
Where are the DHCP settings and how do I navigate to them?
Thanks !
1 Reply
It is the Dynamic Host Configuration Protocol. Not something you should mess around with without good reason.
What do you want to do? You have a problem you want to fix?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Connect to the Network
