jomega
Feb 26, 2017Follower
Disabling NAT
I have an R6400 Nighthawk, and I'm trying to use it as a router/gateway/dhcpd, without NAT, so that the wireless hosts and hosts on the WAN network can all talk to each other by their respective IPs. ...
- Feb 27, 2017
Home routers generally have no way to turn off NAT, and Nighthawk routers are no exception.
Are WAN devices on the internet, or are they on a local network that is immediately upstream of the router???
There is the AP mode, which I think might do what I want, but the Nighthawk will then grey out lots of features. Routing features, DHCP services are greyed out, restricting connections by MAC address, even traffic stats are greyed out as well.AP mode doesn't route at all. It provides WiFi for the main network, and the ethernet is simply switched onto the main network. Routing and DHCP are handled by the upstream router.
That is the closest mode to what you want.
TheEther
Feb 27, 2017Guru
What you want to do (i.e. disable NAT but still function as a router/DHCPD) is not supported.
Can you explain why you want this functionality?
