medicdad73's avatar
medicdad73
Disconnecting issues 6900v2
I have searched in here looking for a answer, it seems since I updated to the newest firmware, even the beta R6900v2-V1.2.0.14_1.0.1_beta, the router diconnects all the time if there is any inactivity. I know its the router because I have a external drive attached to it and it won't connect either. Anyone have any suggestions? I am at a lost here, I have reset the router, downloaded the earlier firmware R6900v2-V1.2.0.8_1.0.1 and nothing works.
TIA
  • Hi medicdad73,
    1. Please make sure you do a factory reset after updating the router's firmware.
    2. Does it disconnect all your devices (wired and wireless)?
    3. Have you tried reflashing the firmware?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi medicdad73,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi medicdad73,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • HaVoChRiS's avatar
        HaVoChRiS
        Hello, I'm experiencing same issues. I have done the factory reset and updated to the latest firmware as described above.
