golfnut1969
Apr 01, 2017Guide
Dismal internet speeds
So, I'm getting ready to buy a new router. I have a cable internet connection that guarantees 100 mbps. If I connect my laptop directly to the cable modem, I get 134.3 mbps download and 5.8 mbp...
- Apr 03, 2017
Thanks for all the replies. However, even with the bandwidth limits of old equipment, I think I should have gotten better speeds. I should have noted in my original post that I have 8 available wireless networks showing up at my home, all from neighbors. At least half of these are showing 3 bars or more so they're pretty strong signals. I think I was getting a lot of interference from neighbors, and my old router just didn't have the power to get through all these.
Note, I just said old Router. I bought a NETGEAR R6400 - Wireless-AC1750. Now I'm getting 141 mbps download when wired, 132 mbps on 5 GHz and around 71 mbps on the 2.4 GHz channel. So, I've put all the kid's phones, Kindles, and other stuff on the 2.4 GHz channel, my wife and I on the 5 GHz and I wired the XBox and my laptop in my office and wife's laptop in the kitchen.
I'm happy with the performance I'm getting now. Thanks again.
William10a
Apr 01, 2017Master
First thing the router only has 10/100 mb internet and lan ports so you 100mb service is your top speed it will handle the wifi performance may be around 40 to 70 mbs if lucky a firmware update may help some if you ever want to get a faster internet speed you will need a new router for any speed above the 100mb range. A firmware update and resetting up may restore some life back into router but the router is near it's limits now
here is the users manual for http://www.downloads.netgear.com/files/GDC/WNDR3300V1/WNDR3300_SM_12Nov07.pdf
It is a dual band by the way 2.4 and 5 ghz bands if you replace it you use as access point if needed for a remote building.
michaelkenward
Apr 02, 2017Guru - Experienced User
William10a wrote:First thing the router only has 10/100 mb internet and lan ports so you 100mb service is your top speed it will handle ..
And remember, that 100 Mbps is on a network that is handling two-way traffic and loads of other stuff, so a single operation isn't going to have all of that capacity and get you even that theoretical top speed.
You are using a wireless router that is more than 10 years old, the manual is dated November 2007. It was made before we could hope for ISPs to deliver 100 Mbps.
Its wifi technology is of the same vintage.
- William10aApr 02, 2017Master
I just realiizedthat my old back up router is better then I believed it was awndr3400v1 handing 72 mbs in to internet port and 72 mb out of the lan ports with 54 mbs on its 2.4 ghz band 50mb on the 5 ghz band depending the time of day.
