hjorslev
Jul 09, 2016Follower
DMZ and port forwarding at the same time
I am on the hunt for a new router. Unfortunately, the router provided by my new ISP doesn't support using port forward and DMZ at the same time. My old router a Linksys E4200 is supporting port forward and DMZ at the same time. I am aware, that I can't forward more than one port to my single public IP address, but I have a virtual server which I use to host severeal games (Insurgency and Arma 3), and it is so much easier just have that particular server using DMZ instead of port forward.
Does anybody know whether the R6400 – AC1750 Smart WiFi Router—802.11ac Dual Band Gigabit supports DMZ and port forwarding at the same time?
Hi hjorslev,
Yes, you can perform DMZ to a single LAN IP within your network and do port forwarding simultaneously. You can check the device user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Dexter
Community Team
1 Reply
- DexterJBNETGEAR Moderator
Hi hjorslev,
Dexter
Community Team
