Nigel_F
Mar 02, 2016Aspirant
DNS resolution slower through router
I am trying to set up Outlook 2016 with an outlook.com account. It times out when it searches for the site. I unplug the router and plug the modem directly into my computer. Try again. It doe...
- Mar 02, 2016
Run a DNS bench mark utility(there are many freeware out there) to find best and fast DNS for you.
VE6CGX
Mar 02, 2016Master
- Nigel_FMar 10, 2016Aspirant
Thanks. The issue turned out be different than excpected but only discovered through using a utility.
I used this
https://testconnectivity.microsoft.com/
it actually told me that the problem was with my installation of Outlook. Why it worked when connected directly is sort of unexplained. But the tip off was not having the problem on multiple computers and no issue connecting through wifi when setting up the same account with difffernt apps.
Thanks for the info
