simplex1
Feb 02, 2017Aspirant
Does an WNDR3400 work as an wi-fi repeater if the security of the main router is set to WPA2-PSK (AE
Does an WNDR3400 work as an wi-fi repeater if the security of the main router is set to WPA2-PSK (AES)? I have an WNDR3400|N600 router which I want to use as a Wi-Fi repeater. Can I do it for th...
- Feb 02, 2017
simplex1 wrote:
The question is, what security is this (WEP or None), is it between me and the WNDR3400v1, is it between the WNDR3400v1 and the main router, or simply the security for both connections has to be set to WEP or None
The entire wifi network needs to be either WEP or none. WEP was cracked long ago, so it is not secure.
William10a
Feb 03, 2017Master
The wndr3400v1 can use wpa2 personal and if you use dd-wrt it has a reaper function I beleive that the netgear firmware has it too. As the wdnr3400v1 is listed as end of service life in the netgear support section under downloads. Your opions are open people still the Linksys wrt54g a g router with third party firmware as repeaters 12vots dc and you have mobile repeater with limited features.
Feb 03, 2017Guru - Experienced User
If you have ethernet at that location, you could set it up as an access point instead.
There is no direct UI support for it, but there is some information here: https://community.netgear.com/t5/WiFi-Routers-802-11b-g-n-Legacy/Need-help-setting-up-WNDR3400-as-access-point-or-repeater/m-p/505485/highlight/true#M1211
- William10aFeb 03, 2017Master
With 100mbits ports a lan ports on a wndr3400v1 an over power adaptor should work to turn the wndr3400v1 into a access point.
- michaelkenwardFeb 03, 2017Guru - Experienced User
William10a wrote:With 100mbits ports a lan ports on a wndr3400v1 an over power adaptor should work to turn the wndr3400v1 into a access point.
Powerline rather than "over power"? Or is that what you mean?
Or bin the wndr3400v1 and get Powerline wifi.
- StephenBFeb 03, 2017Guru - Experienced User
That depends on how the building is wired. In the US office buildings often have much longer runs to the circuit breaker boxes, and are receiving 3-phase power that is then split.
It's worth a try, but running ethernet might be a better option.
