simplex1
Feb 01, 2017Aspirant
Does an WNDR3400 work as an wi-fi repeater if the security of the main router is set to WPA2-PSK (AE
Does an WNDR3400 work as an wi-fi repeater if the security of the main router is set to WPA2-PSK (AES)? I have an WNDR3400|N600 router which I want to use as a Wi-Fi repeater. Can I do it for th...
- Feb 02, 2017
simplex1 wrote:
The question is, what security is this (WEP or None), is it between me and the WNDR3400v1, is it between the WNDR3400v1 and the main router, or simply the security for both connections has to be set to WEP or None
The entire wifi network needs to be either WEP or none. WEP was cracked long ago, so it is not secure.
William10a
Feb 04, 2017Master
I'am sorry that I may seem like some of my question do not may sense But I like to be able see in my mind the picture of the issue and be able to break it down in to parts. It is easier to remove the parts of the problem then you can divide the problem into half's. The reason I even posted the information the remote link the wifi signals they want in building from a different building makes there are two separate buildings and no way to run a cat 5 or 6 cable or use powered lan is out because of different power feeds.
Feb 04, 2017Guru - Experienced User
I think Michael is just asking you to use quotes (or some form of punctuation) around the text you copy/paste. That would make it easier to follow some of your responses.
- michaelkenwardFeb 05, 2017Guru - Experienced User
StephenB wrote:
William10a wrote:I'am sorry that I may seem like some of my question do not may sense
Yes.
And please do not post a reply, edit it and post it again and again and again.
