GuidanceSkeeker
Oct 13, 2015Aspirant
DoS Attack by Multiple IP's?
Hello, i have a NETGEAR WNR2500 router and have recently experienced a DoS attack from what looked like multiple IP addresses according to my router log. I have tried everything to stop the person wh...
- Oct 21, 2015
The next time you see the [LAN access from remote] logs, you can open a Command Prompt as Administrator on the targeted machine (assuming it's running Windows) and run netstat -b to obtain a listing of network connections and user processes that is responsible for each connection. In the example above, the LAN access targeted port 15930 on your computer, so you would look for that port in the netstat. If the owner process looks suspicious, then your computer could be compromised.
As I recommended already, you should disable uPNP. If your computer is compromised, it could be using uPNP to open ports in your router to allow unsolicited incoming traffic from the Internet.
GuidanceSkeeker
Oct 17, 2015Aspirant
I that, i cant answer with full confidence, but i can say i have never seen that ip in my logs before. Are you saying that could be the hacker?
TheEther
Oct 17, 2015Guru
192.168.1.11 is being targeted by all of the remote traffic.
- GuidanceSkeekerOct 21, 2015Aspirant
Okay i see. Then that would be my computers IP.
- TheEtherOct 21, 2015Guru
