grace0nfire
Sep 12, 2015Aspirant
Dos Attacks
[DoS Attack: Land Attack] from source: 255.255.255.255, port 67, Saturday, September 12, 2015 15:58:56 [DoS Attack: Land Attack] from source: 255.255.255.255, port 67, Saturday, September 12, 2015 1...
- Sep 13, 2015
Ok. Port 67, along with port 68, is used for DHCP. It's a little strange for the router to be complaining about DHCP unless somehow it's detecting a large burst of DHCP Requests in a short period of time.
According to your logs, the timestamps between "attacks" are several minutes to several hours apart, so it doesn't seem to be happening all that frequently and is probably not a real DoS attack. Perhaps you have an old device on your network that doesn't have a good DHCP Client implementation. If you are not seeing any performance or network issues, then I wouldn't worry about it.
grace0nfire
Sep 13, 2015Aspirant
No I do not have access control on.
TheEther
Sep 13, 2015Guru
- grace0nfireSep 13, 2015Aspirant
Okay. Thank you so much for replying. That really helped me!
