bob_m10
Nov 20, 2018Aspirant
Enable Access Point Mode
Hi All,
I have the R6050 and confused as to the purpose of the Enable Access point mode? In my case I beleive I am already using the R6050 as an AP but not using this option. I connect one ...
- Nov 20, 2018
The Access Point mode would be a quick cut to reconfigure everything, sometimes even the WAN/Internet port (some newer routers allow using all Ethernet ports in AP mode - but not sure about yours), disabling the DHCP server, disabling the routing/Internet, ... and get a DHCP client active so the device does get an IP address assigned by your other DHCP server.
michaelkenward
Nov 21, 2018Guru - Experienced User
There is support for the R6050 at the end of this link:
>>>R6050 | WiFi Router | NETGEAR Support<<<
See the section Use the Router as a Wireless Access Point.
Probably easier than home-rolled settings.
