Gloverjac
Nov 25, 2018Aspirant
Enable parental controls
I have an open dns account with parental controls, but my genie ap will not let me enable the parental controls. When I slide the enable button it thinks for a while and turns it off.
- Nov 25, 2018
Try the newer firmware.
WNDR3400v3 Firmware Version 1.0.1.22 | Answer | NETGEAR Support
You may need to reset to factory defaults after the new firmware.
Gloverjac
V1.0.1.18_1.0.63
michaelkenward
Nov 25, 2018Guru - Experienced User
Yes, but what is the hardware?
Sorry, but life is too short to chase through all the Netgear hardware to find which firmware versions site on which devices.
Hint, fill on the bit on all messages that says:
Model (Recommended - Helps the community give the best answers)
You can also help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reasons. One of which is to get you more quickly to possible answers.
