Gloverjac
Nov 25, 2018Aspirant
Enable parental controls
I have an open dns account with parental controls, but my genie ap will not let me enable the parental controls. When I slide the enable button it thinks for a while and turns it off.
- Nov 25, 2018
Try the newer firmware.
WNDR3400v3 Firmware Version 1.0.1.22 | Answer | NETGEAR Support
You may need to reset to factory defaults after the new firmware.
Gloverjac
Wndr3400v3
michaelkenward
Nov 25, 2018Guru - Experienced User
- GloverjacNov 25, 2018AspirantThank you. It worked.
- michaelkenwardNov 25, 2018Guru - Experienced User
That's great news. It works sometimes.
