dsherry
Oct 28, 2015Guide
error message with log emails
hi, I am getting this error message after having tried to set up e-mailing of the log file for my router [email failed] SMTPclient: smtp.mail.yahoo.com: unknown host On the e-mail ...
Retired_Member
Oct 28, 2015Check your outgoing server smtp is usually outgoing while mail is incoming but hey I'm just guessing, can't say I ever have seen smtp.mail.???.???
dsherry
Oct 28, 2015Guide
https://help.yahoo.com/kb/SLN4724.html
POP server settings for Yahoo Mail
POP lets you connect your Yahoo Mail account to a desktop mail client or mobile app. It uses 1-way synching, which downloads your email as a copy into the app, allowing you to move and delete them in the app without affecting the original emails. Here are the settings you'll need to configure your mail client or app.
Incoming Mail (POP) Server
- Server - pop.mail.yahoo.com
- Port - 995
- Requires SSL - Yes
Outgoing Mail (SMTP) Server
- Server - smtp.mail.yahoo.com
- Port - 465 or 587
- Requires TLS - Yes (if available)
- Requires authentication - Yes
Your login info
- Email address - Your full email address ([email protected].)
- Password - Your account's password.
- ElaineMOct 29, 2015NETGEAR Employee Retired
Is this working before?
What's the exact model number and version of your device?
- dsherryOct 29, 2015Guide
Elaine,
It is an N150
Hardware Version WPN824N Firmware Version V1.0.0.22 GUI Language Version V1.0.0.53 Thanks
It's the first time I have tried to set up the email function.
