aj2015
Jul 19, 2017Tutor
Ethernet Connection not detected
I have this strange situation with my connection. I had an Arris Modem and R6250 was hooked up with that. During a thunderstorm, I saw that there was no power on my router. Sure enough, the AC adapt...
DexterJB
Jul 19, 2017NETGEAR Moderator
Hi aj2015,
You can try performing a loop back test to check if the ports are working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
DexterJB
Jul 24, 2017NETGEAR Moderator
Hi aj2015,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- aj2015Jul 25, 2017Tutor
I tried the loopback test. There are no dedicated LAN LEDs on R6250. The lights below the individual ports (which usually light up when a cable is connected ) did not turn on. Lights for power and wifi on the front are the only ones which are on.
