favemuppet's avatar
favemuppet
EX6120 Extender WPS LIght
Can someone give me an affirmative answer please as I have seen many conflicting....
Once my EX6120 extender has been connected to my Sky Router (set up via web browser), should the WPS light be solid green?
If it isn’t solid green, does that mean there is no security on my extender (even though you need a password to join and router is set to WPA2-PSK(AES)?
  • > [...] I have seen many conflicting....
       Where?  Thanks for the helpful links.
       Have you considered the obvious approach?:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "WPS"?
    > [...] should the WPS light be solid green?
       I'll admit that the User Manual is not especially clear on this.  I'd
    assume that the WPS light is normally off, blinks for a couple of
    minutes after you press the WPS button, and goes solid (for a while, at
    least) when a WPS connection is established.
       What behavior do you see?
    > If it isn't solid green, does that mean there is no security on my
    > extender [...]
       Obviously not, because:
    > [...] you need a password to join and router is set to WPA2-PSK(AES)
       I'd expect the WPS light to do something when WPS is being used to
    let a device make a wireless connection to the extender.  As a security
    feature, the extender is not always receptive to a WPS connection
    request; it's receptive only for "two minutes" after you "press the WPS
    button on your router or access point."  And the WPS light flashes.
       After the connection has been established, and the WPS light goes
    solid, WPS is no longer needed.  And the WPS light times out after
    indicating success.
    • favemuppet's avatar
      favemuppet
      Thanks for taking the time to reply.
      Conflicting views are techies on a Facebook group (yes I know what you are going to say) saying that the WPS light should only ever be blinking when connecting, and never on afterwards, and also posts on this forum saying the same thing - compared to various YouTube videos showing set up and implying it should always be on.
      I have indeed RTFM (the full one, not the quick setup one), and it also implies that the WPS light should be solid green after connecting. It is silent about whether it should go off a short while after.
      The behaviour I have seen is that it blinks during the connection process, but NEVER goes solid.
      I tried an EX3700 before I got the EX6120 and this behaved exactly the same way. I sent it back as faulty.
      • antinode's avatar
        antinode
        Guru
        > are going to say) [...]
           What I'd say say is that even if you had supplied helpful links to
        any of that stuff, I likely wouldn't put much time+effort into reading
        stuff on Facebook, and I'd rather rub sand into my eyes than watch a
        typical "technical" movie on YouTube.  "implying"?
           But the connection succeeds?
           Defects in Netgear documentation and/or firmware are not especially
        unusual, sad to say.
