chandansikdar's avatar
Jan 01, 2020
EX6150v2 setup
As my wifi router has changed, I have done a factory reset of the extender EX6150v2  in order to set it up again. I am able to connect to NETGEAR_EXT. However when I click on the New Extender Setup in mywifiext, nothing happens after shortly displaying the message "waiting for mywifiext". Please suggest how to address the issue. If you need any additional information please let me know.
Regards
Chandan
  • I usually prefer to set these up with a hardwired connection to them if possible. it tends to go faster/smoother.
    Have you tried the setup using a different computer or browser? Sometimes thats the issue
    there's also the potential of setting up via wps. Have you tried that option?
    Here's the support site with video guides, the install guides, the manual, and firmware.
    https://www.netgear.com/support/product/EX6150v2.aspx
  • plemans's avatar
    • chandansikdar's avatar
      chandansikdar
      Initiate
      Thanks plemans for your advice. I could get it by changing the browser from Chrome to Explorer. Now I have set it up right.
      Regards
      Chandan
      • plemans's avatar
        Glad to hear you got it working! let us know if you have more issues and we'll be happy to help
