Schmoozer
Feb 06, 2021Tutor
EXT3700 Acess Point speed issue
I am using mine as an access point.
My wifi cable modem doesn't reach the basement well. I have a small home and I'm using this extender as an access point (not repeater).
I ran a 50 ft cat6 cable and my speed is only 90 mbps.
To try and troubleshoot I tried a 50 ft cat8 cable. No improvement.
I plugged the same 50 ft cat8 cable into my tower (granted i know hardwire is always faster than wifi...) but my desktop speed is 300-350 mbps.
It says that the extender supports 433 mbps so why is the speed only 90 mbps.
How can I lose 66 to 75% of my speed going through the extender?
Because the EX3700 only has a 10/100mbps port and not gigabit?
- Didnt realize that...so why would it say it supports 433? Its supposed to support 433 as a repeater? I get like 25 mbps in repeater mode
Repeater mode is even worse.
Reason why is extenders have to go router----extender and then extender-----device using the same chip. And it can't do both at once. so in repeater mode, its throughput is actually half of what its getting from the router.
And the numbers for wireless are always overblown.
I'd take a read of this to see what I mean.
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
