brian1388's avatar
brian1388
Initiate
Mar 14, 2023
FIRMWARE update R6220
I have been trying for two years to update my firmware to the latest version, and all I have is issues. My version is ancient, and I really want to get it current. When I download it, I open it and I get a message "the disk image file is corrupted". If I try using the app, it keeps telling me it can't find new firmware.
  • A lot of people double click on the extracted file and expect it to install.
    You don't do that.
    Once its extracted, you log into the router and upload that file to the router as detailed in the manual update process Kitsap posted.
    Did you do that or did you try opening the file?
    What is the version number of the firmware now on your router?
    Specifically how are you trying to open it???
    Have you unpacked the img file from the zip file?
    Are you working on Windows or Mac?
    Do you have a real computer you can connect to your router?  Preferably via Ethernet cable.
    Have you reviewed the instructions for manually updating firmware here:
    https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
  • plemans's avatar
    You don't do that.
    • michaelkenward's avatar
      michaelkenward
      This seems to be especially common among Mac users.
      And it doesn't help that Netgear sometimes uses and .img file and at other times a .chk files. Both have very different alternative uses as file extensions.
      Most Netgear manuals tell people what to do. But users seem to be a reluctance to go to the trouble of reading that stuff. Hence the constant flow of similar messages here.
    • brian1388's avatar
      brian1388
      Initiate
      Thanks all, I have successfully installed the latest firmware.
