type36lotus's avatar
Apr 10, 2022
Firmware upgrade DHCP
Will be updating to firmware 1.1.0.112, from .84(?).  Will DHCP assigned IP addresses change when this process completes?
I have VoIP phone system where the routing of calls to individual phones is based on the phone's IP address.  The vendor felt that fixed IP addresses were not needed, contrary to my belief and wishes.
Thank you in advance,
Mike
    • type36lotus's avatar
      type36lotus
      Tutor
      "It shouldn't."  That is what I am hoping for.  My concern is that if it does assign new IPs I will disable two law offices.  They will not be happy.  I do have a plan for a future implementation to assign all phones fixed IP addresses from a consecutive range.  I am going to take your advice and define each phone's current MAC addr and IP address as reserved.  It won't look neat, but should do the job, certainly better than being surprised when the IPs move around.
      I will update with results.
      Mike
        type36lotus
        Tutor
        The results are in and mixed.   I did reserve(aka fixed, static) all the VoIP phones IP addresses to their respective mac address.  This worked as it should phones retained their earlier assigned IP addresses.   The DHCP devices were possibly random, but maybe not.  Some retained the pre-update IP address, some did not.  I need to check a device which retained its IP addr. and one that did not.  At one time I needed to uncheck the NIC properties "Allow the computer to turn off this device to save power".  This very much so kept the machine for obtaining new IP addr during sleep/lock states and the software accessing the device from failing to connect(it was saving the last IP used address).
