atlantic
Jan 09, 2017Aspirant
firmwear upgrade for 582384
I started the process for the upgrade and walked away from my computer. I am not sure if the upgrade happened. Where can I check this and what version would be indicated? Thank you.
There are links to the firmware updates for the affected routers here: http://kb.netgear.com/000036386/CVE-2016-582384
What router model do you have?
What is a 582384?
- atlanticAspirant
Security Vulnerability: VU#582384
The Vulnerability:
NETGEAR is aware of the security issue #582384 that puts a network at risk by allowing for unauthenticated web pages to pass the command-line interface leaving open the potential for arbitrary command execution by remote attack.- StephenBGuru - Experienced User
