swharrell
Dec 16, 2016Follower
fishy email
Just received this email...looks fishy. Discussion in July 2016 on this subject was "solved"...is this email legit or not? Security Vulnerability: VU#582384 The Vulnerability: NETG...
- Dec 17, 2016
Nothing fishy about it, although that is a natural response. Just Netgear keeping customers informed:
Solved: Two leading Netgear routers are vulnerable to a se... - NETGEAR Communities
There's plenty more where that came from.
Did you follow the links in the email you received?
michaelkenward
Dec 17, 2016Guru - Experienced User
- Fred__Dec 17, 2016Aspirant
When try downloading the firmware update I get a pop up box that says "all wireless connections will be terminated". Is this a normal request; is it permenent?
Nighthawk AC1900
Thanks in advance.
- michaelkenwardDec 17, 2016Guru - Experienced User
Downloading from where? Using a hard (wired) connection or a wifi link?
If you are saving the file locally, then when you upload the firmware flash it will close your internet connection and reboot the modem/router. The wifi will come back on then.
Thanks for the reply. Downnloading from Netgear website and using a hardwire connection as recommended.
Yes, I saved the file to my hard drive; so it sounds like if I continue with the download the terminations will not be permenent?
Thanks again.
