LeShek's avatar
LeShek
Frequent reset required on R6300 to restore wifi
Firmware: V1.0.2.78_1.0.58   I have to frequently reset R6300 to restore wifi.  Only soft reset is required, just power off and on.   Hardwired connectivity is nor affected.     Sometimes it is ...
  • DexterJB's avatar
    DexterJB
    Dec 26, 2016
    Hi LeShek,
    You are welcome.
    1. You can try the NETGEAR Genie WiFi Analyzer for Android. There are more powerful ones for PC like inSSIDer that you can look in to.
    2. A factory reset clears the device's memory that may sometimes get rid of recurring issues. Yes, you can save the router's configuration and restore it. You can check the links below.
    http://kb.netgear.com/app/answers/detail/a_id/24231
    http://kb.netgear.com/24232/
    Dexter
    Community Team
