jkonz's avatar
jkonz
FS108 DC Power Supply
Hello,
I am looking for more information about what is the acceptable DC input power range for the FS108. The datasheet only says 7.5V at 1amp. But there must be an allowable range, can someone please specify?
Thanks!
  • > Would like to know if either 5V or 9V would work instead of 7.5V.
       I'd need to look at the design of the regulator of the FS108 to
    decide that question.  My guess would be that higher would be more
    likely to work than lower, but whether the design would tolerate that in
    the long term is another question (to which I lack the answer).
       A quick+dirty(+cheap) scheme might be to put a couple of Si diodes in
    series with the 9V supply to drop/waste about 1.4V.  Not classy, but
    probably good enough.  And a little better than a direct connection to
    9V.
  • > I am looking for more information about what is the acceptable DC
    > input power range for the FS108. [...]
       Why?
    > [...] there must be an allowable range, [...]
       No doubt, but there'd be no reason for Netgear to publish it.  I'd
    guess that +/-10% (on the voltage) would be fine.
    • jkonz's avatar
      jkonz
      I need to install this unit as part of a larger assembly and will not be using the standard AC to DC wall adapter. Would like to know if either 5V or 9V would work instead of 7.5V.
      Thanks
        9V.
  • michaelkenward's avatar
    michaelkenward
    The ProSAFE range is pretty esoteric kit compared with the General WiFi Routers (Non-Nighthawk) devices covered in this bit of the forum. I doubt if ProSAFE experts hang out here.
    You might get better and quicker replies, and find other answers, over in the appropriate section. That's probably here:
    Switches - NETGEAR Communities
    or here
    Smart / Plus / Click Switches - NETGEAR Communities
    There might even be a Netgear specialist following that area.
