Orbipro1
Jun 21, 2021Aspirant
Geofencing WiFi 6
Are there any Orbipro, or other WiFi router , gateway that has a geofenced wifi access?
olympos1625
Jun 26, 2021NETGEAR Employee Retired
Hi Orbipro1,
Good day!
Welcome to NETGEAR Community!
You may check the Netgear XR1000 Nighthawk Pro Gaming router.
https://www.netgear.com/home/online-gaming/routers/xr1000/
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Orbipro1
Jun 29, 2021Aspirant
The router you referred appears to have a feature that is a form of geofencing. The description says the geofence applies to the game server that is joined in a restricted vicinity.
My goal is to I geofence my small office router to restrict access from devices outside the fenced range.
- antinodeJun 30, 2021Guru
> from devices outside the fenced range.What sort of "fenced range" would that be? Radio in GHz frequencies
is rather naturally range-limited.How would the router know its own location? How would the router know
the location of some other device (especially one to which it has not
established a connection)? How would you specify the boundary?Is there some actual problem which you are trying to solve?
General advice: You might have more success if you described
(clearly) the actual problem which you are trying to solve, rather than
asking how to implement some particular "solution" ("geofenced wifi
access") which might have little or nothing to do with the actual
problem, if it exists at all.- Orbipro1Jun 30, 2021Aspirant
The problem is secure restricted logical and physical access to the wireless and wired lan network.
750 square foot apartment.
devices have location awareness with NFC and Bluetooth in range of router, and other means.
both device and router would have to be capable
maybe a Fido standard for wireless access.
Coincidentally, some Lifi companies promote secure proximity data exchange. Though those are still developing.
> wireless and wired lan network.You have some, or you want some?
"physical access to the [...] wired [LAN]" is normally dealt with by
running cables to only secure places.> both device and router would have to be capable
So, all you need is a router with hardware and software which no
Netgear router has? And devices which do not suffer from similar
limitations?> 750 square foot apartment.
Hang some aluminum foil?
