Orbipro1
Jun 21, 2021Aspirant
Geofencing WiFi 6
Are there any Orbipro, or other WiFi router , gateway that has a geofenced wifi access?
antinode
Jun 30, 2021Guru
> Unfortunately the modem, router, access points can be virtualized and
> spoofed.
And location data can't?
> Yes these are enhancement and development request.
There is a designated place where suggestions (including fantasies)
go to die:
https://community.netgear.com/t5/x/idb-p/idea-exchange-for-home
Orbipro1
Jun 30, 2021Aspirant
I don't have time to do your product development, navigate the site, or experience with blogs.
sorry if your offended.
fairly universal objective.
best wishes
- antinodeJun 30, 2021Guru
> or experience with blogs.Not my product. I don't care.
If you say so. I have my doubts.
- Orbipro1Jul 03, 2021Aspirant
Thank you.
I have not learned gaming. I am not familiar with the gaming server environment you mentioned. Is this for a game room setup where there are gamers near a group,of servers?
- antinodeJul 03, 2021Guru
> [...] I am not familiar with the gaming server environment you
> mentioned. [...]Which "you"?
> You may check the Netgear XR1000 Nighthawk Pro Gaming router.
Did you look at the XR1000 User Manual?
> [...] Is this for a game room setup where there are gamers near a
> group,of servers?Of course not.
Visit http://netgear.com/support , put in that model number, and look
for Documentation. Get the User Manual. Read. Look for "geo". Note
that it refers to "the distance from you [that is, your router] to the
host or server of the game", _not_ to the distance between you [that is
your wireless device] and your own router.
[...] We recommend that you set a distance radius in the range
from 500 km to 3,000km (311 mi. to 1,864 mi.).Does that sound to you like what you want?
- Orbipro1Jul 27, 2021Aspirant
> [...] I am? Me, the poster Orbipro1
replying to : Schumaku.
a gaming server 300-1900 miles away? What if local network desktop server and distance from device to server.
I sorry I'm not versed. I meant distance from device to router and transmitter in a local area or closed network. For example a digitized library that grants access to devises digital in its surrounding common areas, or extended areas in offsite common areas and access points.
Or range restricted access to the local area to reduce vulnerable surface area from spoofs, interception, man in the middle.
- antinodeJul 27, 2021Guru
Well, duh. The question was 'Which "you"?', as in "the gaming server
environment _YOU_ mentioned".
> replying to : Schumaku.Wrong thread? Put "@" in front of that user name? Otherwise, why
would he see it?> a gaming server 300-1900 miles away? What if local network desktop
> server and distance from device to server.Then apparently geofencing (as normally defined) has nothing to do
with your problem. Which was my point three weeks ago.
