Fuggal's avatar
Fuggal
Google Chromcast won't connect to WNDR4300 router
I'm having trouble connecting my Chromecast in a long-term vacation rental that has the WNDR4300 router. My iphone and computer connect just fine to the house's WiFi network. The Chromcast recognizes the same network and I can choose it when I try to do the Chromecast setup, but I get the message "Could not connect to WiFi." I've gone through all Chromecast troubleshooting steps (on my own and then on a chat with a Chromecast representative). For what it's worth, I can use my wife's cell phone as a hotspot and connect the Chromcast through the WiFi seamlessly.
It seems the issue has been narrowed to a problem with the router settings (or firmware?) that is preventing the Chromcast connection. The chat representative suggests the "AP isolation" is enabled and I need to disable it. There are other settings that may need to be disabled as well, like virtual private networks (VPNs), proxy servers, and IGMP Proxy.
Can someone suggest how I can do this? I have the problem that this is a rental house and I am not the registered owner of the router. Can I access setttings somehow?
Thanks for any help!!
  • This might help eg. for the WNDR4300: Chromecast will not connect to wifi
    From the above link:
    Here are the detailed steps to find that box:
    I have a Netgear WNDR4300 router that was blocking my new chromecast from connecting via the wifi password. I was typing it in correctly but it kept giving me the error "Connection problem during setup! - Chromecast could not connect to Netgear - Please check your password". I spent hours trying to resolve it only to realized it came down to one option in my router settings.
    • Go to your router settings by typing your ip in to a browser
    • Click on advanced in the upper left corner
    • Click on 'Setup' -> QoS Setup
    • Check the box next to "Enable WMM (Wi-Fi multimedia) settings for which ever frequency your wifi is connecting to (2.4 or 5ghz)
    • Click 'Apply'
    • Reset your chromecast and start the app up again and that's it!
  • schumaku's avatar
    schumaku
    • Click 'Apply'
    • Fuggal's avatar
      Fuggal
      Oh my, it worked!!! Thank you so much.
      Enabling that WiFi multimedia setting was the issue (it makes perfect sense now once you've pointed it out).
      Like you, I spent many hour on this (several days, actually).
      You saved me!!!
