Spaztic
Mar 20, 2021Aspirant
Gs608 ethernet switch crashes internet
When plugging in and turning on the Ethernet switch it stops my router and internet services working, what could be the issue
A few more details might help.
What modem do you have?
What router do you have?
how is it connected? Are you going Modem---switch---router
or how exactly is it connected in your setup?
> When plugging in and turning on the Ethernet switch [...]
What, exactly, is connected to what, exactly? (Hint: If a device has
different types of Ethernet ports, then "connected to device" is not
enough detail.)Are you connecting only a switch port to a LAN port on the router, or
are other devices connected to the switch, or what? Is the switch
causing the problem, or is some device which is connected to the switch
causing the problem, or what?
