BogeyBob's avatar
BogeyBob
Follower
Oct 24, 2015
Guest connection to N600 router
I've had this router for a long time, and never needed to have a guest connect to the Wi-Fi in my house.  Now I do, and don't know where to find the guest network access password.  I'm sure its in the setup somewhere, but where?
  • You didn't provide the model number of your router.
    Generally, when you log into your router, you should see a Guest Network panel or tab on the home page. Click on it to access the guest network settings. Setup should be self-explanatory. If not, go to http://support.netgear.com, enter your router model and download the user manual.
1 Reply
