jimdevonshire
Apr 27, 2016Aspirant
Guest Network Disclaimer Notification
Is there a third party App I can use to present a disclaimer to my guests using my Guest Network? Some coffee shops offering free WiFi ask the customer to please use the service responsibly and to no...
- Apr 28, 2016As I mentioned, none of the Netgear's routers support a captive portal. I see that their business class wireless management controllers support it.
TheEther
Apr 27, 2016Guru
The support you are looking for is called a captive portal. AFAIK, this is not available on Netgear routers using stock firmware. Some models can run 3rd party firmware, like DD-WRT, which have support for captive portals like Chillispot, Sputnik and others.
jimdevonshire
Apr 28, 2016Aspirant
Thanks for your advice but it is all greek to me. Do you know of a NetGear model that would support this type of portal ? From what you say my current model doesn't.
JW
