jimdevonshire
Apr 27, 2016Aspirant
Guest Network Disclaimer Notification
Is there a third party App I can use to present a disclaimer to my guests using my Guest Network? Some coffee shops offering free WiFi ask the customer to please use the service responsibly and to no...
- Apr 28, 2016As I mentioned, none of the Netgear's routers support a captive portal. I see that their business class wireless management controllers support it.
TheEther
Apr 28, 2016Guru
jimdevonshire
Apr 29, 2016Aspirant
Thank you for the clarification. To bad their isn't a residential class of router that would support a portal as mentioned. As a small business owner a device as you mentioned would not be in my budget.
JW
