6400v2notgood's avatar
Oct 04, 2022
Have to reset R6400v2 daily
Like the subject says it drops daily. Last netgear anything I buy. Thanks!
  • plemans's avatar
    Well, thats not much info.
    Whats all dropping? Wifi and wired?
    And what error is it giving you? Is it stopping broadcasting the ssid entirely? or is it saying "connected, no internet"?
    What happens with wired devices?
    What modem/gateway is it connected to?
    What firmware is on it?
    Is it a new device? If so, you have free support for 90 days. To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
  • michaelkenward's avatar
    michaelkenward
    That's is not "like the subject says": "drops daily" is not the same thing as "reset daily".
    Have you done anything to troubleshoot your problems and to check that it isn't something else on your network that is the issue?
