koinabeda's avatar
koinabeda
Follower
Sep 14, 2022
Hello, back with another question.
So I’ve setup my r6700 in bridge mode, but I’m not sure if I’ve done it right. Do I have to do anything to the other router I have, or do I just set it in bridge mode and devices can connect to the NETGEAR router?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Are you having some sort of problem? Is it set up and not working? Something else?
    What do you mean by "bridge mode"? I ask because that term gets used in different ways.
    Earlier this week someone used the tag to describe wireless access point (AP) mode.
    You probably mean as a wifi repeater, but best to check. It could also be as a WDS.
