Moetmoet's avatar
Moetmoet
Help me open router port to access remote view on my ip security camera
Hello, I need help finishing setting up my Home security camera, so that I can use the camera remotely and not just while my device is on same wifi as camera. My camera is wired directly to my router, and works fine when I am on the same network. Please help me figure out how to open the router port or whatever I need to do to access remote viewing
  • My house was broken into last night and I need to set this up tonight before I have to leave for work tomorrow with no access to my camera. Anything helps, thank you
  • > [...] my Home security camera, [...]
       Not a very detailed description of that device.
    > [...] works fine when I am on the same network [...]
       When you do what, exactly?  Web browser?  Some app or other?  The
    non-psychics in your audience might be able to provide more specific
    guidance if you provided some basic information.
    • Moetmoet's avatar
      Moetmoet
      Hey **bleep**wit, either respond to help, or don’t. Sitting here analyzing the way I’m asking for help ain’t helping anyone, no life having scumbag.
      NEEDED HELP WITH PORT FORWARDING ON THE IP OF A IP540 Victure Security camera, moron.
      I figured it out without your help. So kindly **bleep** off
    • Moetmoet's avatar
      Moetmoet
      You’re such a trash person sensei, get the hell out of here, no one likes you
    • Moetmoet's avatar
      Moetmoet
      If you’re that big of a retard, you shouldn’t be offering to help people with thinky thoughts bud.
