YOUNES's avatar
YOUNES
Follower
May 16, 2021
HOW CAN I ACTIVATE 2.4 FREQUENCY ON THE NETGEAR ROUTER
Anytime i try to scan a document it says that an error occured , i spoke to hp technical support and they told me that i need to activate the 2.4 frequency
1 Reply
  • plemans's avatar
    You gave us a lot to go off.
    1. what netgear router do you have?
    2. what are you scanning with?
    3. Why do you think its a router issue when you're using a scanner?
