Retired_Member's avatar
Retired_Member
Dec 07, 2025
How can I purchase a PAV12V25 power adapter?
I can see this adapter on the Netgear website, but I can't see where to purchase one.
  • CrimpOn's avatar
    CrimpOn
    Search on Amazon.  I found several from $12 to $22.
    • Retired_Member's avatar
      Retired_Member
      Amazon was one of the first places I looked. I found plenty of power adapters, but I did not find this exact model.
      • StephenB's avatar
        Are you sure the PAV12-100NAS won't work.  It has the same specs.  Maybe check the compatibility list on Amazon.
  • plemans's avatar
    You could always pickup a third party adapter. As long as the voltage is the exact same and it has at least the same amperage, it'll work. I've swapped power supplies around before when ones gone missing or stopped working. It works fine.
  • plemans's avatar
    Also make sure the polarity is the same too. I had one random one that was swapped
