KED1's avatar
KED1
How do I connect my wifi range extender to my nowtv router? It doesn’t have a WPS button
1 Reply
  • What extender did you buy?
    There is a netgear installation assistant you can use instead of wps.
    here's the video of how to use:
    https://www.youtube.com/watch?v=yJVklshxBMk
    you can also go to netgear.com/support/
    type in your model number and it'll take you to install guides, manuals, firmware, etc.
