HelpN750
Sep 19, 2014Aspirant
How do I connect to my 5Ghz Network with my LAN?
So I'm going to preface this with a note that I believe I have some idea of what's going on but I could actually have no idea whats going on and make no sense. So be prepared for that. I have a WND...
- Sep 27, 2014If you are setting up a WiFi capable router (as you are) using a computer that has no WiFi capability but is connected by the router via Ethernet, then you can ignore the wireless setup of the router. However if you expect that at some time other computers that are WiFi capable might want to connect to the router then you should still set up the router wireless settings, you should set the SSID (network name) and encryption for both bands (2.4GHz and 5GHz). If you don’t plan to use the router WiFi at all, you can disable both bands so that the router will not transmit any WiFi signals at all and will only use wired connections (Ethernet cable).
Mars Mug
Sep 20, 2014Virtuoso
HelpN750 wrote: I have a LAN connected to the router into my computer and would like to be using the 5 Ghz network, but it has automatically set me up on the 2.4 Ghz network. I've tried every way I can think of of disconnecting and reconnecting and going on the NETGEAR Genie but nothing seems to work.
What has ‘automatically set me up on the 2.4 Ghz network’? Isn’t that the computer doing that? You say you have ‘tried every way I can think of of disconnecting and reconnecting’ but what did you try? Normally for a dual band WiFi adaptor all you need to do is use the option to ‘forget’ the 2.4GHz band connection, it will then ‘forget’ the encryption details and will not try to connect automatically, then you should scan for WiFi networks and try to connect to the 5GHz band, have you done that?
