HelpN750
Sep 19, 2014Aspirant
How do I connect to my 5Ghz Network with my LAN?
So I'm going to preface this with a note that I believe I have some idea of what's going on but I could actually have no idea whats going on and make no sense. So be prepared for that. I have a WND...
- Sep 27, 2014If you are setting up a WiFi capable router (as you are) using a computer that has no WiFi capability but is connected by the router via Ethernet, then you can ignore the wireless setup of the router. However if you expect that at some time other computers that are WiFi capable might want to connect to the router then you should still set up the router wireless settings, you should set the SSID (network name) and encryption for both bands (2.4GHz and 5GHz). If you don’t plan to use the router WiFi at all, you can disable both bands so that the router will not transmit any WiFi signals at all and will only use wired connections (Ethernet cable).
HelpN750
Sep 26, 2014Aspirant
http://imgur.com/a/KQMdt
Okay I think I might have found my problem, and it might be a stupid one. So as you can see, I was initially confused because of the 'Wireless Settings' tab in the second picture saying 2.4 Ghz and I wanted it to be 5. But as you can see I'm not even connected via the WiFi.
So if I have this 100% clear, if I am connected via an ethernet crd the Dual Band system is totally irrelevant? Like it doesn't even run on a 2.4/5 Ghz network it's something totally different?
