Johnz414
Jun 06, 2017Aspirant
How do I setup ipvanish on netgear N600 router?
Hi, Just that. How do i setup ipvanish on a Netgear N600 router? Thanks, John
- Jun 16, 2017
It is from Asus.
This is the wrong place for fixing Asus problems.
michaelkenward
Jun 07, 2017Guru - Experienced User
Netgear makes dozens of N600 routers. Which one do you have?
Look for the model number:
Then you can find the manual on Netgear's support site.
- Johnz414Jun 15, 2017Aspirant
It is a Netgear RT-N53 Dual-Band Wireless N600.
I've seen options where you have to install the DD-WRT firmware to add the VPN but when I looked at the DD-WRT site it didn't seem to offer a firemware for this router?
Also, I just found this YouTube video explaining how to set a a VPN without flashing the router. I would like to know if this would work for the router I am working on?
- ElaineMJun 16, 2017NETGEAR Employee Retired
That model sounds from a different manufacturer. You can verify the model number here.
The router doesn't support IPVanish unless you use a different firmware or hardware.
- michaelkenwardJun 16, 2017Guru - Experienced User
It is from Asus.
