Johnz414
Jun 06, 2017Aspirant
How do I setup ipvanish on netgear N600 router?
Hi, Just that. How do i setup ipvanish on a Netgear N600 router? Thanks, John
- Jun 16, 2017
It is from Asus.
This is the wrong place for fixing Asus problems.
ElaineM
Jun 16, 2017NETGEAR Employee Retired
That model sounds from a different manufacturer. You can verify the model number here.
The router doesn't support IPVanish unless you use a different firmware or hardware.
michaelkenward
Jun 16, 2017Guru - Experienced User
It is from Asus.
- Johnz414Jun 23, 2017Aspirant
I've moved the question to an ASUS forum, sorry for the mixup.
