MNCoop
Jan 04, 2017Aspirant
How do I track device bandwidth on R6400?
My cable provider is going to charge me for bandwith usage, and I need to determine what device(s) are using all of my bandwidth up. I have an R6400|AC1750. Can I monitor device usage on this ...
- Jan 05, 2017
Hi MNCoop,
The router does not support the feature of monitoring the bandwidth usage of the connected individual devices. However, you can check the traffic meter feature and see if it is something that can help out.
http://kb.netgear.com/app/answers/detail/a_id/24225
Dexter
Community Team
DexterJB
Jan 05, 2017NETGEAR Moderator
Hi MNCoop,
Dexter
Community Team
MNCoop
Jan 05, 2017Aspirant
I was afraid that was the answer. :smileysad:
Thanks for the quick reply.
- StephenBJan 06, 2017Guru - Experienced User
There are some suggestions that might be helpful here: http://www.howtogeek.com/222740/how-to-the-monitor-the-bandwidth-and-data-usage-of-individual-devices-on-your-network/
If you want to stay with Netgear firmware in the router, you can find apps/software for most of your devices that can measure this. iOS is one big exception.
