RP2176
May 29, 2016Initiate
How do I use my own router instead of the one my ISP gives
I recently changed ISP to At&t U-verse (my only choice), they gave me the NVG599 modem with built in router. I have a Netgear N900 that I want to use, how would I do that? I read that the NVG599 doe...
- May 29, 2016
I like these instructions. They're for the NVG589 but they will work on the NVG599, as well.
Note, the NVG599 should have better Wi-Fi than your N900 because it supports 802.11ac. Of course, your devices also need to support 802.11ac to take advantage. Don't mistake me, I'm all for installing one's own router, especially for control. It's what I do. But if speedy Wi-Fi is what you are after, a N900 might be a step down.
TheEther
May 29, 2016Guru
- RP2176May 29, 2016Initiate
Okay, Thanks for the advice and the instructions.
