ukhanjemb
Sep 22, 2022Follower
How in the world do I fix my Netgear N300 Wireless Router?
I've looked through posts but they're still over my head. I have no idea what I need to do here. What is the log-in thing I need to do with the generic password? (login = admin, password = password...
Sep 22, 2022Guru - Experienced User
What model is this NG router, WNDR#####?
Press the reset button for 10 seconds then release. Have 1 wired PC connected to the back. Use a web browser to walk thru the setup wizard at 192.168.1.1 or routerlogin.com
This is a fairly old model router. You might consider upgrading to something a bit newer.
