Jellicoe
Feb 03, 2015Tutor
How to add a mac address access control
I am a bit confused here. I see that there is the access control page, but I can not figure out how to add a new iPad? Rachael
Babylon5
Feb 03, 2015NETGEAR Employee Retired
I’m at work at the moment, and don’t have access to the ‘4500 manual to check, but I suggest that you temporarily disable the Wireless Access List, let the iPad connect, then enable the list and select the iPad as a trusted device.
