Jellicoe
Feb 03, 2015Tutor
How to add a mac address access control
I am a bit confused here. I see that there is the access control page, but I can not figure out how to add a new iPad? Rachael
Jellicoe
Feb 05, 2015Tutor
Well, after hours of messing around with the router and it not being able to see my iPad while the other router did, I tossed the Netgear Router and just connected everything to the Motorola router that came with the DSL. Everything works. I will look for a new dual band router later and not let my brother upgrade the firmware.
The WDNR4500 has always been trouble, and I just got tired of it. I got that router so I can print from my iPad, but that never really worked without messing everything up with apps on the iPad and then it was a pain in the buns to print from the desktop.
So thanks for your help. One less router and a bunch less problems
Rachael
Rachael
