Trollzer's avatar
Trollzer
Follower
Jul 20, 2018
How to change access blocked message?
I actually have the 6700 but it's not showing up. I'd like to not have the access blocked thing show up. My old FiOS router just stopped the connection without showing a message.
  • schumaku's avatar
    schumaku
    Jul 21, 2018
    Guess the OP does talk about this message ...
    ...caused by the mostly obsolete* Netgear Security -> Block Sites -> Keyword Blocking feature:
    Of course, the code does reside somewhere...trying to change the message is mostly a waste of time, as the time is near where browsers default to https and the feature is becoming definitively obsolete.
    To answer this short: No, the access blocked message is not customizable from the Web UI.
  • michaelkenward's avatar
    michaelkenward
    What "access blocked thing"? Where do you see it?
    • schumaku's avatar
      schumaku
