ducari3's avatar
ducari3
How to connect a wrt150n and a wndr3400v2 together to expand wireless connection
How to connect those two routers together wirelessly but with the first as main router without losing my security and port forwarding setting? Thank you by advance for your help!
  • ducari3's avatar
    ducari3
    Jul 08, 2016
    Thank you for help. The wndr3400v2 is enough for my home. So, problem solved.
