twakalowski
Jun 06, 2018Aspirant
How to disable Wireless AP mode
On the "ADVANCED home" page for my router, under both 2.4 ghz and 5 ghz it lists Wireless AP as being on, despite not being enabled in ADVANCED>Advanced Setup>Wireless AP. How do I disable Wireless A...
- Jun 06, 2018
> ADVANCED>Advanced Setup>Wireless AP. How do I disable Wireless AP?
Two different things: "Wireless AP" and "[Wireless] Access Point
Mode".
Strictly speaking, a "wireless access point" is the part of the
wireless router which handles the wireless communication. The R6400 has
one for each frequency band, and that's what the ADVANCED > ADVANCED
Home page controls. Disabling an AP switches off that radio, but
doesn't affect other router functions.
Wireless access point _mode_ is a mode of operation which disables
most/all of the router functions, leaving only the wireless access point
functions. That's what ADVANCED > Wireless Access Point : Enable Access
Point Mode controls. If that box is unchecked, then your R6400 should
be in full-function router mode.
What would you like the R6400 to do?
michaelkenward
Jun 07, 2018Guru - Experienced User
If you want to turn off the wifi, press the switch on the top. (Second from the right.)
There is a manual for the R6400 somewhere at the end of this link:
>>> R6400 | Product | Support | NETGEAR <<<
See page 11.
You can also do it with the browser interface. See page 118.
If you use the switch, be warned that you will not be able to turn the wifi on using the browser interface.
AP mode is completely different. It does not turn of the wifi, but changes the router's fundamental way of working. Switch to that mode and you no longer have a router as most people understand it. People use AP mode so that they can use the box with a different router and turn it into a wifi extender.
