niekn
Dec 05, 2016Aspirant
How to easily block a device from the network
How can i easily block/disconnect a device on my network, when it is already connected to it?
by useing genieapp i can easily block or unblock a device by "accessing" the network, but when it has already a connection
it does not block it untill de device needs a new connection/stream etc..
router i have is WNDR4500
Welcome to the community, niekn
There's no way to easily block it once it connected to the network.
You may perhaps, try to shut off the wireless connection in order for that device to reconnect.
So when it tries to reconnect, it will now be blocked.
- yosemitedyessAspirant
You cansend a deauth to that connection and it will force it to disconnect won't it?
- nieknAspirant
How to send this command ? to disconnect a device
http://www.aircrack-ng.org/doku.php?id=deauthentication That should help you out.
